Trendnet USB Wireless Adapter
Free - as-is - doing spring cleaning and hoping someone else can benefit - device was working last time I used it years ago.
Would be suitable for low performance applications, such as IoT, sensors, etc. Would work on a laptop or desktop, but don’t expect speed.
Model: TEW-648UBM
The N150 Micro Wireless USB Adapter (model TEW-648UBM) quickly connects a laptop or desktop computer to a high speed wireless n network. Enjoy proven wireless n speed and reliability, in a micro design that extends less than three eighths of an inch (9mm) from the edge of a computer. Connecting to a network is made easy with the external one-touch Wi-Fi Protected Setup (WPS) button. Advanced wireless encryption protects your valuable data. Wi-Fi Multimedia (WMM) Quality of Service (QoS) prioritizes important video, audio, and gaming traffic. Seamlessly stream video, download files, and play games with this ultra compact wireless n adapter.
- 1 x USB 2.0 connector
- Ultra compact form factor
- Wi-Fi compliant with IEEE 802.11n standard
- One-touch wireless connection with external Wi-Fi Protected Setup (WPS) button
- Backwards compatible with IEEE 802.11g and IEEE 802.11b devices
- Supports 64/128-bit WEP, WPA/WPA2-RADIUS, and WPA-PSK/WPA2-PSK
- Wi-Fi Multimedia (WMM) Quality of Service (QoS) data prioritization
- Coverage of up to 30 meters indoor (98 feet) and 50 meters outdoor (164 feet) *
Notes:
- This is a 2.4 GHz only device — no 5 GHz support.
- 150 Mbps is the theoretical max; real-world throughput will be significantly lower, typically 50–80 Mbps under good conditions.
Technical Specs:
N150 Micro Wireless USB Adapter - TRENDnet TEW-648UBM
If you’re interested, send me a direct message.
Thanks!
